Initial Project Goals and Considerations
A project log for MPSM V2 Direct Drive for 2.85/3.00mm Filament
These modifications will allow this printer to use a direct drive extruder, and print using 2.85mm/3.00mm filament
mc88MC88 01/08/2022 at 01:220 Comments
Objectives
  1. Print with 2.85/3.00mm filament as it is becoming quite cheap and can be used when 1.75mm filament is out of stock
  2. Reduce overall noise level during printing - the noise level must be (subjectively) negligible when beside the printer
  3. Minimize cost by using stock components when possible
Evaluation
Objective 1: Print with 2.85mm/3.0mm filament
Objective 2: Reduce overall noise
Objective 3: Minimize cost
