5. Setting time
A project log for GPS disciplined 555 clock
Can we make a precise clock with analog indicators driven by 555s?
jan-waclawekJan Waclawek 01/10/2022 at 01:200 Comments
A clock needs also some method to set it to the current time.
Here, we could simply add two normally-off switches/pushbuttons(/relay contacts) to each stage's capacitor, each connecting the capacitor through a suitable resistor to 1/3 VCC and 2/3 VCC respectively, for discharge (adjust down) and charge (adjust up).
