Roomba_MQTT_daemon.pyPython service/daemon to run on a Pi for logging and mapping (and to do loop closures and error correction in the future)text/x-python - 9.78 kB - 09/02/2022 at 09:53 |
Roomba_MQTT.serviceservice file for systemctl to run the python script as a serviceservice - 297.00 bytes - 09/02/2022 at 09:53 |
MQTT_Config.pyMQTT-credentials for python servicex-python - 80.00 bytes - 09/02/2022 at 09:53 |
Zip Archive - 6.28 kB - 08/28/2022 at 19:30 |
Roomba632_2022-08-21.cppLibrary source containing the Roomba632 classv.2022-08-21 plain - 26.09 kB - 08/21/2022 at 18:51 |
Roomba632_2022-08-21.hLibrary header containing the Roomba632 classv.2022-08-21 plain - 6.25 kB - 08/21/2022 at 18:51 |
Roomba632_2022-08-21.zipComplete library containing the Roomba632 classv.2022-08-21 Zip Archive - 11.53 kB - 08/21/2022 at 18:50 |
arduino_secrets.hEnter your own credentials and info.plain - 347.00 bytes - 08/11/2022 at 20:21 |
Zip Archive - 52.10 kB - 04/06/2022 at 20:32 |
ESPAsyncTCP-master.zipDependency for the Async MQTT-clienthttps://github.com/me-no-dev/ESPAsyncTCP Zip Archive - 51.53 kB - 04/06/2022 at 20:32 |
MPU6050_Arduino.zipLibraries needed to interface with the MPU6050 using i2CZip Archive - 488.52 kB - 01/23/2022 at 19:58 |
MPU6050.pdfDatasheetAdobe Portable Document Format - 1.56 MB - 01/23/2022 at 19:56 |
Adobe Portable Document Format - 635.45 kB - 01/23/2022 at 19:56 |
Create_2_Serial_to_33V_Logic.pdfLogic level shifting using a FETAdobe Portable Document Format - 727.24 kB - 01/22/2022 at 19:22 |
Adobe Portable Document Format - 4.35 MB - 01/22/2022 at 19:22 |
