Assembly
A project log for Smart classic AC doorbell
Assimilating my classic RRRRRRING!! doorbell into the hive.
simon-jansenSimon Jansen 01/12/2022 at 21:590 Comments
Ok, design is done. Now for the actual build. The Eagle board layout feature helped me to set up the components in a logical way with easy wiring. Trying to use single sided wiring as much as possible means the least crossing wires (in theory)
Which translates to the following:
And after one burned out transistor replacement (which was a pain to diagnose), I'm up and running!
