Autodiscover MQTT in Home Assistant
04/24/2022 at 17:00 • 0 commentsBecause I spent so much time on this, doesn't mean we all have to. This python script configures a "doorbell" device in Home Assistant via MQTT.
This device has:
- A switch / toggle for the mute state. This also updates its own state;
- A button to ring your own doorbell "cuzz ya can";
- A trigger event as a "short button press" that you can use in automations;
#!/usr/bin/env python # (c) 2022-04-24 S.E.Jansen. # Copyright (c) 2014 Adafruit Industries # Author: Tony DiCola #versie = "1.0" import time import paho.mqtt.client as paho import subprocess import MQTT_Config import GPIO_Config import json #call back function def on_connect(client, userdata, flags, rc): if rc==0: client.connected_flag=True #set flag print("connected OK") else: print("Bad connection Returned code=",rc) client.bad_connection_flag=True #Make connection with MQTT broker and paho.Client.connected_flag=False #Create flag in class paho.Client.bad_connection_flag=False #another flag client= paho.Client() #create client object client.username_pw_set(MQTT_Config.user,MQTT_Config.password) client.on_connect=on_connect #bind call back function print("Connecting to broker ",MQTT_Config.broker) client.connect(MQTT_Config.broker,MQTT_Config.port) #establish connection client.loop_start() #start network loop while not client.connected_flag and not client.bad_connection_flag: #wait in loop print("In wait loop") time.sleep(1) if client.bad_connection_flag: client.loop_stop() #Stop loop sys.exit() #the main loop starts here print("in Main Loop") print("Adding Doorbell " + GPIO_Config.ID + " action trigger") #Add doorbell button; as an action trigger topic = MQTT_Config.HA_name + "/device_automation/Doorbell_Button_" + GPIO_Config.ID + "/action_pressed" config_payload = {"automation_type":"trigger", "payload": "visitor", "value_template": "{{value_json.value}}", "unique_id": "Doorbell_Button_" + GPIO_Config.ID, "topic":topic + "/action", "type":"action", "subtype":"button_short_press", "icon": "mdi:doorbell", "device": {"identifiers":[("Doorbell_" + GPIO_Config.ID)], "name":("Doorbell_" + GPIO_Config.ID), "manufacturer": "X", "model": "001", "suggested_area": GPIO_Config.location}} client.publish(topic + "/config",json.dumps(config_payload),0,True) time.sleep(1) print("Adding Doorbell_" + GPIO_Config.ID + " button") #Add doorbell; as output topic = MQTT_Config.HA_name + "/button/Doorbell_" + GPIO_Config.ID config_payload = {"name": GPIO_Config.location + " doorbell", "unique_id": "Doorbell_" + GPIO_Config.ID + "_ring", "name": "Doorbell_" + GPIO_Config.ID + "_ring", "command_topic": topic + "/set", "payload_press": "ring_short", "icon": "mdi:alarm-bell", "device": {"identifiers":[("Doorbell_" + GPIO_Config.ID)], "name":("Doorbell_" + GPIO_Config.ID), "manufacturer": "X", "model": "001", "suggested_area": GPIO_Config.location}} client.publish(topic + "/config",json.dumps(config_payload),0,True) time.sleep(1) print("Adding Doorbell_" + GPIO_Config.ID + " mute switch") #Add doorbell; As switch. With state and command topic topic = MQTT_Config.HA_name + "/switch/Doorbell_" + GPIO_Config.ID config_payload = { "unique_id": GPIO_Config.location + " mute switch " + GPIO_Config.ID, "name": GPIO_Config.location + " mute switch", "state_topic": topic + "/state", "command_topic": topic + "/set", #"payload_on": "{\"mute_set\":\"ON\"}", #"playload_off": "{\"mute_set\":\"OFF\"}", "state_on": "1", "state_off": "0", "value_template": "{{value_json.mute_state}}", "retain": True, "icon": "mdi:alarm-bell", "device": {"identifiers":[("Doorbell_" + GPIO_Config.ID)], "name":("Doorbell_" + GPIO_Config.ID), "manufacturer": "X", "model": "001", "suggested_area": GPIO_Config.location} } client.publish(topic + "/config",json.dumps(config_payload),0,True) time.sleep(1) client.loop_stop() #stop connection loop client.disconnect() #gracefully disconnect client.connected_flag=False #reset flag
I updated the python daemon accordingly. It has to listen to two topics and the action/trigger topic is also different.
Hope this is helpfull for someone. I spent almost a full day on the changes and it is still not perfect. I can't get the switch or the button to use the JSON payload. I really don't know where else I can put escapes or more single or double quotes. In the end I decided to skip the JSON for commands.
Also when the daemon encounters a non-JSON command on a subscribed topic, it crashes.. The code should use some proper exception handling, but I don't wanna.
#!/usr/bin/env python # (c) 2022-04-24 S.E.Jansen. #import lybraries #import RPi.GPIO as GPIO from gpiozero import Button as Button from gpiozero import DigitalInputDevice as DigitalInputDevice from gpiozero import DigitalOutputDevice as DigitalOutputDevice import time import GPIO_Config import MQTT_Config import json import paho.mqtt.client as paho #setup pins button = Button(GPIO_Config.button, pull_up=False, bounce_time=0.05,hold_time = 3, hold_repeat=False) bel = DigitalOutputDevice(GPIO_Config.bel) mute_state = DigitalInputDevice(GPIO_Config.mute_state, pull_up=True, bounce_time=0.05) mute_set = DigitalOutputDevice(GPIO_Config.mute_set) mute_reset = DigitalOutputDevice(GPIO_Config.mute_reset) #GPIO functions and callbacks def visitor(): #on rise of input (debounce 50ms) the doorbell has rung print("doorbel press detected") data = {'value':"visitor"} client.publish(MQTT_Config.HA_name + "/device_automation/Doorbell_Button_" + GPIO_Config.ID + "/action_pressed/action",json.dumps(data),0,False) #MQTT connection + callback functions def on_message(client, userdata, message): #check and handle incomming messages to: # - ring bell # - check mute status # - set bell to mute / unmute data = message.payload receive=data.decode("utf-8") #print(m_decode) #print (m_decode['Server_name']) if message.topic == MQTT_Config.HA_name + "/button/Doorbell_" + GPIO_Config.ID + "/set": #m_decode = json.loads(receive) #buttonpress = m_decode["doorbell"] buttonpress = receive print ("Button message received: " + buttonpress) if buttonpress == "ring_short": bel.blink(on_time=0.1, n=1) if message.topic == MQTT_Config.HA_name + "/switch/Doorbell_" + GPIO_Config.ID + "/set": #muteCommand = m_decode["mute_set"] muteCommand = receive print ("Command received for mute: " + muteCommand) #switch: for if muteCommand == "ON": print("setting mute") mute_set.blink(on_time=0.5, n=1) time.sleep(0.1) data = {'mute_state':mute_state.value} client.publish(MQTT_Config.HA_name + "/switch/Doorbell_" + GPIO_Config.ID + "/state",json.dumps(data),0,True) elif muteCommand == "OFF": print("resetting mute") mute_reset.blink(on_time=0.5, n=1) time.sleep(0.1) data = {'mute_state':mute_state.value} client.publish(MQTT_Config.HA_name + "/switch/Doorbell_" + GPIO_Config.ID + "/state",json.dumps(data),0,True) elif muteCommand == "ENQ": #check status of relays. B-side is inverse of "mute" and is connected to GND. #Pi is set with internal pull-up. Normal operation is mute off (bell rings normaly) #A-side is closed, B-side is open.Therefore internall pul-up gives a value of 1. #value of mute is therefore inverse of pin-value. #mute = True means silent operation. mute = False means ring! data = {'mute_state':mute_state.value} client.publish(MQTT_Config.HA_name + "/switch/Doorbell_" + GPIO_Config.ID + "/state",json.dumps(data),0,True) #def MQTT_AutodiscoverConfig(): #send config to MQTT broker for autodiscover in Home Assistant # print("send Autoconfig message with MQTT") #init #Set callbacks: #Doorbell button button.when_pressed = visitor #button.when_long_press? #Mute change detect #mute_state.when_changed? #MQTT client #client_on_message = MQTT_message #client_on_connect .. etc #call back function for MQTT connection def on_connect(client, userdata, flags, rc): if rc==0: client.connected_flag=True #set flag print("connected OK") # MQTT subscribe to command topic to receive commands (in json format) client.subscribe(MQTT_Config.HA_name + "/button/Doorbell_" + GPIO_Config.ID + "/set",0) print("Subscribed to: " + MQTT_Config.HA_name + "/button/Doorbell_" + GPIO_Config.ID + "/set") client.subscribe(MQTT_Config.HA_name + "/switch/Doorbell_" + GPIO_Config.ID + "/set",0) print("Subscribed to: " + MQTT_Config.HA_name + "/switch/Doorbell_" + GPIO_Config.ID + "/set") data = {'mute_state':mute_state.value} client.publish(MQTT_Config.HA_name + "/switch/Doorbell_" + GPIO_Config.ID + "/state",json.dumps(data),0,True) print(json.dumps(data)) else: print("Bad connection Returned code=",rc) client.bad_connection_flag=True #call back function for disconnect MQTT connection to reconnect #def on_disconnect # MQTT details paho.Client.connected_flag=False #Create flag in class paho.Client.bad_connection_flag=False #another flag client= paho.Client() #create client object client.username_pw_set(MQTT_Config.user,MQTT_Config.password) client.on_connect=on_connect #bind call back function client.on_message= on_message #attach function to callback client.connect(MQTT_Config.broker,MQTT_Config.port) #establish connection client.loop_start() #start network loop while not client.connected_flag and not client.bad_connection_flag: #wait in loop time.sleep(0.1) if client.bad_connection_flag: client.loop_stop() #Stop loop sys.exit() # MQTT Home Assistant autodiscover config # MQTT subscribe to command topic to receive commands (in json format) client.subscribe(MQTT_Config.HA_name + "/button/Doorbell_" + GPIO_Config.ID + "/set",0) print("Subscribed to: " + MQTT_Config.HA_name + "/button/Doorbell_" + GPIO_Config.ID + "/set") client.subscribe(MQTT_Config.HA_name + "/switch/Doorbell_" + GPIO_Config.ID + "/set",0) print("Subscribed to: " + MQTT_Config.HA_name + "/switch/Doorbell_" + GPIO_Config.ID + "/set") data = {'mute_state':mute_state.value} client.publish(MQTT_Config.HA_name + "/switch/Doorbell_" + GPIO_Config.ID + "/state",json.dumps(data),0,True) print(json.dumps(data)) #for silent testing.. #print("engage silent mode") #mute_set.blink(on_time=0.5, n=1) #time.sleep(0.1) #print("mute status: ") #print(mute_state.value) while True: try: # print("still running") time.sleep(10) except KeyboardInterrupt: client.loop_stop() #stop connection loop client.disconnect() #gracefully disconnect client.connected_flag=False #reset flag mute_reset.blink(on_time=0.5, n=1) time.sleep(0.1) print("mute status: ") print(mute_state.value) print("returned doorbell to normal opperation") print("Ending program") exit()
And supporting config files:
#MQTT_config broker="xxx.xxx.xxx.xxx" port=1883 user="xx" password="xx" HA_name="homeassistant"
#Pins (GPIO numbering) button=18 bel=23 mute_state=27 mute_set=24 mute_reset=25 #Unique sensor ID ID="XX" location="location"
Systemd services file:
[Unit] Description=Managing doorbell with MQTT After=network.target [Service] ExecStart=/home/user/python/GPIO_MQTT_daemon.py WorkingDirectory=/home/user/python StandardOutput=inherit StandardError=inherit Restart=on-failure User=user [Install] WantedBy=multi-user.target
As always: use at your own risk :)
Software and integration into the hive
01/12/2022 at 22:00 • 0 commentsI wrote a python script that can be run as a service. This way it has automatic startup at boot and if it fails.
It subscribes to a "set" MQTT-topic for commands. It sends the actual state of the mute relay to a "state" topic. And when it senses the doorbell being rung, it sends a message to a "trigger" topic.
This gives me full controll in Home Assistant.
Assembly
01/12/2022 at 21:59 • 0 commentsOk, design is done. Now for the actual build. The Eagle board layout feature helped me to set up the components in a logical way with easy wiring. Trying to use single sided wiring as much as possible means the least crossing wires (in theory)
Which translates to the following:
And after one burned out transistor replacement (which was a pain to diagnose), I'm up and running!
Figuring out schematic and components
01/12/2022 at 21:58 • 0 commentsOk. So the raspberry Pi GPIO's can only handle 3.3V max. I found some solutions that use a full rectifier and then pass the result through a linear voltage regulator. I bet this works, but it feels wrong somehow.
I chose to go with only a single diode and a capacitor to rectify and dampen the signal.
Some clamping diodes to VDD and GND will make sure I'm within GND - 0,7V and VDD + 0,7V. (I don't have any schottky's laying around). And a last voltage divider with two resistors to really make sure I don't go above VDD.
This gave me the chance to (re)learn how to do schematics and simulation. So (quite) a few evenings later:
Then I noticed the relays I had are double latching single coil (I had to google this too). It means they get stuck in ON or OFF position and need a reverse voltage to switch where they also get stuck.
This turns out to be exactly what I want for the mute function that runs in series with the bell-actuator. It just means I have to learn how to do a proper H-bridge. The relays also switch on 5V and the Pi's GPIO-pins give me 3.3V. This means PNP's (I never liked PNP's, they seem upside down somehow and give me headaches)
So another full day of research, and an eventual help-line to someone who knows what they are talking about:
And the full schematic:
I ended up using one double latching single coil relay for the mute function. The relay has two "sides". One inverted to the other. This gives me an input for the actual status, so I can check this on start-up and check if setting or resetting has worked.
The other relays is parallel to the doorbell button to ring it. It is a "normal" active to close 5V relay that I can operate with a transistor or a button on the board.
This all means the following functionality: I can ring the doorbell with a button on the board or with a GPIO-pin output. This is handy for testing and making my neighbours think I have loads of visitors.
I can mute my doorbell and still get a signal when the doorbell button is pressed (or when I operate the ring-relay. Using the on board button OR a GPIO-pin output).
I also added connections for a DHT22 temperature and humidity sensor. Because, why not?
Getting the idea
01/12/2022 at 21:51 • 0 comments
