Floor standing lamp as a wake-up light. Controll with an ESP8266 and MQTT.
- Use RGBW LED strips with standard driver / controller;
- Big light! 2m tall. LED strips stick to aluminium square profile;
- Clear PVC is clamped between wooden top and foot;
- Keep working remote by intercepting IR-signal and control by sending IR-comands;
- ESP8266 for MQTT integration with Home Assistant;
Current status:
It's been in it's current form since 2015. It works but still needs a cover to diffuse the light. I have been planning to get some kind of stretchy fabric like a sock to cover the PVC pipe.
I seem to have misplaced the Arduino sketch since. This has the proper IR-remote codes so I'm not keen on redoing this work. The MQTT-server, credentials, WiFi SSID and other stuff are hardcoded in, so maybe I have to at some point.
_UPDATE_:
Source code is found!
Files
libraries.zip
IRremoteESP8266 & PubSubClient libraries for Arduino
x-zip-compressed -
228.48 kB -
08/24/2022 at 09:55
It was on an older laptop that got passed along and that I happened to get on my desk for some updates. Anyway, glad to have it. Now I can improve on it, add OTA, MQTT-autodiscover etc.
And try to ignore the big cringe you get when you see your own software from a few years ago :|
#ifndef UNIT_TEST#include<Arduino.h>#endif#include<PubSubClient.h>#include<ESP8266WiFi.h>#include<ESP8266WiFiMulti.h>
ESP8266WiFiMulti WiFiMulti;
#include<WiFiClient.h>#include<WiFiClientSecure.h>#include<WiFiServer.h>#include<WiFiUdp.h>#include<IRremoteESP8266.h>#include<IRsend.h>#include<IRrecv.h>#include<IRutils.h>#define PIN_IRLED 10#define PIN_IRSENSOR 4uint16_t RECV_PIN = PIN_IRSENSOR;
unsignedlong previousMillis = 0;
unsignedlong currentMillis = 0;
constlong interval = 60000;
constchar* ssid = "***";
constchar* password = "***";
IPAddress mqtt_server(192,168,1,***);
char* message = "";
WiFiClient espClient;
PubSubClient client(espClient);
IRsend irsend(PIN_IRLED); // An IR LED is controlled by GPIO pin 4 (D2)IRrecv irrecv(RECV_PIN);
decode_results results;
voidcallback(char* topic, byte* payload, unsignedint length){
Serial.print("Message arrived [");
Serial.print(topic);
Serial.print("] ");
for (int i=0;i<length;i++) {
char receivedChar = (char)payload[i];
Serial.print(receivedChar);
if (receivedChar == '0'){
Serial.println(" - Off received");
client.publish("LEDStalamp/Response"," - ALL OFF received");
irsend.sendNEC(0xFF827D, 32);
irsend.sendNEC(0xFFE817, 32);
if (receivedChar == '1'){
Serial.println(" - On received");
client.publish("LEDStalamp/Response"," - ALL ON received");
irsend.sendNEC(0xFF02FD, 32);
irsend.sendNEC(0xFF6897, 32);
if (receivedChar == 'U'){
Serial.println("RGB+ received");
client.publish("LEDStalamp/Response"," - RGB+ received");
irsend.sendNEC(0xFF3AC5, 32);
if (receivedChar == 'X'){
Serial.println("RGB- received");
client.publish("LEDStalamp/Response"," - RGB- received");
irsend.sendNEC(0xFFBA45, 32);
if (receivedChar == 'Y'){
Serial.println("RGB OFF received");
client.publish("LEDStalamp/Response"," - RGB OFF received");
if (receivedChar == 'Z'){
Serial.println("RGB ON received");
client.publish("LEDStalamp/Response"," - RGB ON received");
if (receivedChar == 'R'){
Serial.println("RGB RED received");
client.publish("LEDStalamp/Response"," - RGB RED received");
irsend.sendNEC(0xFF1AE5, 32);
if (receivedChar == 'G'){
Serial.println("RGB GREEN received");
client.publish("LEDStalamp/Response"," - RGB GREEN received");
irsend.sendNEC(0xFF9A65, 32);
if (receivedChar == 'B'){
Serial.println("RGB BLUE received");
client.publish("LEDStalamp/Response"," - RGB BLUE received");
irsend.sendNEC(0xFFA25D, 32);
if (receivedChar == 'W'){
Serial.println("RGB WHITE received");
client.publish("LEDStalamp/Response"," - RGB WHITE received");
irsend.sendNEC(0xFF22DD, 32);
if (receivedChar == 'C'){
Serial.println("RGB R1 received");
client.publish("LEDStalamp/Response"," - RGB R1 received");
irsend.sendNEC(0xFF2AD5, 32);
if (receivedChar == 'D'){
Serial.println("RGB R2 received");
client.publish("LEDStalamp/Response"," - RGB R2 received");
irsend.sendNEC(0xFF0AF5, 32);
if (receivedChar == 'E'){
Serial.println("RGB R3 received");
client.publish("LEDStalamp/Response"," - RGB R3 received");
irsend.sendNEC(0xFF38C7, 32);
if (receivedChar == 'F'){
Serial.println("RGB R4 received");
client.publish("LEDStalamp/Response"," - RGB R4 received");
irsend.sendNEC(0xFF18E7, 32);
if (receivedChar == 'H'){
Serial.println("RGB G1 received");
client.publish("LEDStalamp/Response"," - RGB G1 received");
irsend.sendNEC(0xFFAA55, 32);
if (receivedChar == 'I'){
Serial.println("RGB G2 received");
client.publish("LEDStalamp/Response"," - RGB G2 received");
irsend.sendNEC(0xFF8A75, 32);
if (receivedChar == 'J'...
Thanks Daren! Wouldn't have thought to use mylar, so great tip. You mean the stuff they use for wrapping flower bouquets? I'll be sure to try this when I can find the time to revisit this.
Use mylar, like 10-20 wraps on the inside of the pipe. The cheap kind for wrapping like gift baskets in a clear-ish crunchy thing. Also, make the ends of your chamber reflective.
It creates much more internal reflection of the lights before they escape, diffusing it very effectively.
