Introduction
Would you like to know how to make an audio amplifier circuit?, Audio Amplifiers are an essential part of modern electronics. Basically, it boosts the power of an audio signal by increasing the amplitude of a small sound signal to a useful level, all the while maintaining the smaller signal's parameters. They are one of the most common in use circuits when it comes to electronics and perform a wide variety of functions, So, in this project, we will understand how to make An Audio Amplifier circuit using TDA2030 Amplifier IC.
PCBWay commits to meeting the needs of its customers from different industries in terms of quality, delivery, cost-effectiveness, and any other demanding requests. As one of the most experienced PCB manufacturers in China. They pride themselves to be your best business partners as well as good friends in every aspect of your PCB needs.
Hardware Required
Circuit Diagram
Working Explanation
The working of this circuit is actually pretty simple. An audio input in taken from a device such as a smartphone or a mic. The audio input then goes through a coupling capacitor of 47uF. By using a coupling capacitor we are basically blocking the DC component of the input signal, allowing only AC to pass through. The capacitor output then goes to the non-inverting input pin of the IC.
