Introduction
A circular LED chaser is a simple electronic sequencer usually designed by combining a clock generating device with a counter. the input clock can be of any type such as an astable multivibrator, an inverter, logic gates, a pushbutton, or a dedicated timer IC. The counter can be any of several types including 4-bit, 8-bit, decade, or shift registers, depending on the number of outputs and other features. So, In this project, we are going to build a simple Circular LED chaser circuit using a CD4017 Decade counter IC.
PCBWay commits to meeting the needs of its customers from different industries in terms of quality, delivery, cost-effectiveness, and any other demanding requests. As one of the most experienced PCB manufacturers in China. They pride themselves to be your best business partners as well as good friends in every aspect of your PCB needs.
Hardware Required
Circuit Diagram
Working Explanation
A NE555 timer is connected to the clock input of the CD4017 decade counter IC. The timer IC provides the CLK input of the decade counter with square wave input. CD4017 has 10 output pins and each pin joins to an LED. By default, the first output pin is on or high and the rest are off.
