After working with this board over the weekend there’s a couple changes, I’ve decided to make. Changes include:
- Added screw terminal for input power
- Added TVS diode at input
- Increased board outline
- Update silkscreens indicators
- Update MCU programming pads
Aside form these layout changes the project is sudo-complete, I just need to test this revision and create an enclosure in solidworks. Everythings tested and the firmware is good to go. I'll periodically update the files of this project over the coming week.
