#2 Improvements for 2nd edition
A project log for BW16 Stamp - Tiny 5GHz WiFi Dev Board
Super compact functional 5G Hz WiFi MCU in stamp size with power circuit, work out of the box
simonxiSimonXi 02/11/2022 at 03:250 Comments
  1. Increase the board width to let the board fit into bread board more easily
  2. Increase the tolerance for the outer half holes so that the machining process will not damage too much of the holes' copper coating
  3. AMS1117 has too high of the static current drawn and only able to regulate the power when the batter is above 3.3 V, so I am going to replace with the DCDC power IC from RPI Pico as it can handle both high and low input voltage
