• First signals decoded!
    hebel2301/28/2022 at 18:41 0 comments
    I have tried a bit more with "Universal Radio Hacker". And now I think I found the right configuration to decode the signal. I read that 600 is a typical baudrate for FSK. So I configured the URH interpretation module to this value (Samples/Symbol) and here we are!
    Window sensor 1:
    Window sensor 2:
    The signal from sensor 1 is decoded to  349B.4934.926D.3492.49A.
    The signal from sensor 2 is decoded to 26D2.6BB4.9269.B492.49A.
    The next step is to modify the SignalDuino firmware for the nanoCUL, to receive the same signal.
  • Decoding attempts
    hebel2301/21/2022 at 22:19 0 comments
    The first part of the signal seems to be a synchronization pattern. One bit has a length of ~325µs.
    If I now know the sample/symbol rate the signal should be decoded.
  • URH - Universal Radio Hacker
    hebel2301/21/2022 at 21:54 0 comments
    So this tool seems to be the right choice helping me, to decode the signal!
    First of all I recorded the signal.
    URH can now show the spectrogram:
    The analog view shows this:
    URH can also show the demodulated signal:
    That looks very promising. :-)
  • AIRSPY and Audacity
    hebel2301/21/2022 at 21:43 0 comments
    I did a little research what no I can do with AIRSPY to interpret this unknown signal. I read that the signal can be exported to an audio file. This audio file can be imported by Audacity for example. I played a little bit with both tools but I was not really successful.
    But then (by accident) I found URH (Universal Radio Hacker) !!!
  • SDR-RTL Dongle
    hebel2301/21/2022 at 21:34 0 comments
    I got an cheap SDR-RTL USB dongle on ebay for ~ 20 euros.
    The dongle contains a Realtek RTL2812 and a Realtek R828D chip, which can receive radio signals between ~30 and 1700MHz.
  • AIRSPY SDR Dongle
    hebel2301/21/2022 at 21:30 0 comments
    In the next step I try to receive a signal with an SDR Dongle and the software AIRSPY (SDR#).
    OK, this looks good. I got a signal on 868.475MHz. the two peaks left and right beside the mid frequency is typical for a FSK (frequency shift keying) modulation.
  • First steps with nanoCUL
    hebel2301/21/2022 at 21:25 0 comments
    There are simple and cheap USB dongles that can detect 868 MHz devices. I got myself a "nanoCUL" for this purpose.
    This consists of an Arduino Nano and a Texas Instruments CC1101 radio chip which can be connected to a PC via USB.
    There are several firmware projects for the dongle. SignalDuino, culfw, a-culfw, ...
    I tried them all but unfortunately the protocol is not supported. So I must dig deeper here.
