AIRSPY and Audacity
A project log for Reverse engineering of an unknown 868MHz protocol
Reusing old 868 MHz equipment in openHAB
hebel23hebel23 01/21/2022 at 21:430 Comments
I did a little research what no I can do with AIRSPY to interpret this unknown signal. I read that the signal can be exported to an audio file. This audio file can be imported by Audacity for example. I played a little bit with both tools but I was not really successful.
But then (by accident) I found URH (Universal Radio Hacker) !!!
