Log 3: A Simple Example
01/29/2022 at 21:58 • 0 commentsThe code snippets below provide a complete example. First, we must define the threads and their components and rated power.
accel_thread = epm.Thread(name="Accelerometer Sampling", stages=[ epm.Stage(delta_t_sec=0.5,components=[ epm.Component(name="ESP32",mode_name="Active",current_ma=100.0), epm.Component(name="Accelerometer",mode_name="Active",current_ma=1.5) ]), epm.Stage(delta_t_sec=20.0,components=[ epm.Component(name="ESP32",mode_name="Sleep",current_ma=0.05), epm.Component(name="Accelerometer",mode_name="Sleep",current_ma=0.001) ]) ]) led_thread = epm.Thread(name="LED", stages=[ epm.Stage(delta_t_sec=0.1,components=[ epm.Component(name="LED",mode_name="On",current_ma=5.0) ]), epm.Stage(delta_t_sec=4.9,components=[ epm.Component(name="LED",mode_name="Off",current_ma=0.0) ]) ])
Next, we build the system, with its threads, battery, and energy harvesting. Finally, we calculate the power profile for 3 days while saving the outputs. By default, total net energy will be reported but time histories are not.
this_sys = epm.EmbeddedSystem(name="Test", threads=[accel_thread,led_thread], energy_storage=epm.LithiumBattery(number_cells=1,capacity_mAh=1000.0,current_charge_mAh=500.0,internal_resistance_ohm=0.065), voltage_reg=epm.VoltageRegulator(efficiency=0.8),nominal_voltage=3.3, energy_harvesting=epm.SolarPanel(rated_power_W=1.5,t_offset_sec=0.0)) this_sys.power_profile(3*86400.0, True)
That's it!
Log 2: Battery, Regulator, and Solar Energy Harvesting
01/29/2022 at 21:52 • 0 commentsSummary
These modeling tools follow the block diagram shown below. All of the threads combine to form the "system." This is powered from battery through a regulator. Future features may be added to support more complicated topologies, but this covers many, many designs. The regulator is simple. Currently it simple has a single efficiency number, where 0% corresponds to a linear regulator and 100% efficiency corresponds to an ideal switching regulator. No dynamics, dropout, maximum current capability, efficiency vs. current curve, or other capabilities are currently implemented. Some of these may be added in the future
BatteryCurrently, single and multi-cell lithium batteries are supported. The user selects the number of cells, rated capacity, charge level at the start of simulation, and internal resistance. As the simulation progresses, the battery is charged and discharged. It cannot be charged more than full. This is obvious, but important and sometimes ignored by novices when specifying solar powered systems -- energy can be wasted if there is nowhere to store it. A piecewise linear typical discharge curve is provided, so approximate voltage levels can be seen.
Solar Energy Harvesting ModelThe solar energy model is fairly simple but still capable of representing many real-world phenomena. The user provides a rated power of the panel, which is meant to represent maximum realistic power. Depending on the orientation of the solar panel, this may not be equal to the datasheet value. A very simple peak possible power curve is provided for now, as shown below. The time offset and alpha values can be used to shift the time and season, respectively.
A simple model for cloud cover is also included. The available power is reduced to 10% of the sunlight if under clouds. This is a reasonable value based on my SOL sensor. The presence of cloud cover is determined by whether or not the absolute value of an exponentially correlated random walk process is outside of some set bounds. This process is set up as follows, where g is drawn from a normal distribution with zero mean and standard deviation of one.
The time constant can be used to tune the frequency of clouds, and the threshold value can be used to adjust how much of the day is covered by clouds. The random walk process and corresponding solar power profiles are shown next.
LOG 1: How Components and Threads Work
01/29/2022 at 21:16 • 0 commentsThe power consumption model considers as number of components with specified nominal current consumption. These components are spread out among any number of independent threads. Each thread can have any number of stages. Each stage has a configured length of time that it should run for. All threads repeat periodically. This setup mimics an embedded system running an RTOS, with scheduled tasks and interactions with external components. For example, an LED may be toggled at a prescribed frequency with some set on time. It can be given its own thread so that timing can be separate from other power consumption considerations. As another example, consider a sensor which is sampled every 10 seconds, then placed into a low power mode between samples. This can be readily supported in this thread representation. The image below shows this representation.
The implementation is straightforward. The user must know nominal current consumption of each component in each mode, and the timing between each stage. Currently, it is assumed that all components operate on the same voltage, but that may be changed in the future to allow for separate power buses to be considered. The code snippets below show how two separate threads are built. Here, some accelerometer is periodically sampled by an ESP32, and both the ESP32 and accelerometer enter sleep modes between the sampling. An led thread is created separately.
import embedded_power_model as epm accel_thread = epm.Thread(name="Accelerometer Sampling", stages=[ epm.Stage(delta_t_sec=0.5,components=[ epm.Component(name="ESP32",mode_name="Active",current_ma=100.0), epm.Component(name="Accelerometer",mode_name="Active",current_ma=1.5) ]), epm.Stage(delta_t_sec=20.0,components=[ epm.Component(name="ESP32",mode_name="Sleep",current_ma=0.05), epm.Component(name="Accelerometer",mode_name="Sleep",current_ma=0.001) ]) ]) led_thread = epm.Thread(name="LED", stages=[ epm.Stage(delta_t_sec=0.1,components=[ epm.Component(name="LED",mode_name="On",current_ma=5.0) ]), epm.Stage(delta_t_sec=4.9,components=[ epm.Component(name="LED",mode_name="Off",current_ma=0.0) ]) ])
