OpenTester
Open Hardware / Open Source project for electronics testing and firmware upload
About a 1½ years ago, I designed a stackable piece of development and test equipment for Aerospace hardware development. During a conversation, I found out, that colleagues of mine in my current job had spent 2 years trying to develop something similar.
It gave me the idea of revisiting my old project with a few lessons learned, and I reached out on LinkedIn with a preliminary set of specs and got some nice feedback. I decided to push on with this and make it completely Open Source / Open Hardware, so people can play, expand or just use it if desired.
This is a work in progress and will be updated, as I find the time.
Currently, I've disabled comments, until I have a bit more to show.
Developing and testing (mostly) embedded systems can often require a lot of external equipment for juggling e.g. external pins and / or analog signals.
Based on my old project made for the Aerospace Industry, I've decided to reinvent it and make it Open Source / Open Hardware in the hope, that other could benefit of it and come up with changes and extensions for it.
Currently, I'll be basing the system on the Raspberry Pi 3 (had one lying around) and mostly whatever, I can find in my components storage - mostly due to the components shortage.
  • FINALLY!!!!
    Henrik Sorensen04/28/2023 at 10:47 0 comments
    The last components got delivered... Only a lead time of more than 1 year!!!
    Finally, I can continue with the prototype..
  • Digital I/O Board mk 2 PCB designed
    Henrik Sorensen02/13/2022 at 21:09 0 comments
    Decided to make a simpler prototype of the Digital I/O Board :
    Instead of having the intended STM32(F205) based board featuring nice things as :
    • Onboard test programs
      • Sporting fixed timed sequences
      • Patterns
    • Connecting to the SPI bus using over-engineered addressing decoder functionality
    The board now connects directly to I2C bus but still features the desired functionality :
    • 2 x 8 bit ports which can be either input or output
    • 1 x 8 open switches (Opto Couplers)
    • All connectors aligned with the connectors on the Raspberry Pi for easy front plate design.
View all 2 project logs
