Light Dice
A project log for Circuit Golf: Electronic Dice Edition
Creating Electronic Dice with the least number of components in the most obscure technologies
dr-cockroachDr. Cockroach 02/09/2022 at 20:0515 Comments
This project can be found at https://hackaday.io/project/183942-light-dice
The logic circuit drawing.
Light Dice, Where Light Logic learns how to roll....
Enhanced led display. Yes, the board is printed like that :-D
Putting a ring oscillator, some D latches, a few Nand gates and a dice display together and using only Vactrols. A video and a circuit will be forth coming.
Tim wrote 02/14/2022 at 18:49 point
I think you should be able to shorten your ring oscillator to three inverters :)
Dr. Cockroach wrote 02/14/2022 at 19:51 point
I need to tweak on the circuit more. As it is, its output is sequential so three inverters would only give me 3 outcomes that I can see.... Or am I having a senior moment? ;-)
Tim wrote 02/14/2022 at 20:27 point
I had an Eureka moment when I wrote the part on the bipolar dice ;) .
(The "fully inverted johnson counter" is actually equivalent to a ring oscillator)
Dr. Cockroach wrote 02/15/2022 at 12:08 point
The idea of full inverting was rolling around in my dreams last night.... Going to have to check out that direction :-)
Dr. Cockroach wrote 02/15/2022 at 15:56 point
Ahh haa, I did get a three latch Johnson Counter to give me six output states on Logisim. Now to see if I can get it to work with actual LL. Getting a clean enough clock has been the issue till now so wondering if I can make use of a relay oscillator as the clock.... If that works then the LL gate count will drop by a lot.
Tim wrote 02/15/2022 at 17:17 point
A three stage ring oscillator will give you a six state output.
Dr. Cockroach wrote 02/15/2022 at 18:11 point
Yup, I see the six states, now to get LL to work using a cleaner clock signal. Going to try a relay oscillator for that.
Tim wrote 02/11/2022 at 16:50 point
Impeccable schematics again :)
Dr. Cockroach wrote 02/11/2022 at 17:28 point
Thanks but I really do need to find a easy and basic cad type program. I actually hate hand drawing but learned it back in aviation school ;-)
Tim wrote 02/11/2022 at 17:30 point
I like to (ab)use LTSpice for that. EEschema is also not bad, especially with the new update.
Ken Yap wrote 02/11/2022 at 11:12 point
Is there a reason you mirrored the photo?
Dr. Cockroach wrote 02/11/2022 at 11:47 point
Might not believe me but that is actually how the board was printed :-)
Ken Yap wrote 02/11/2022 at 11:49 point
I hope you got a discount for that. 😉
Tim wrote 02/11/2022 at 04:55 point
Really looking forward to the circuit. Your ring oscillator trick is really neat, I am still trying to figure it whether it is possible to freeze the state of a ring oscillator somehow without having to add additional latches.
Dr. Cockroach wrote 02/11/2022 at 11:01 point
IDK, With my ring oscillator circuit there are fairly large caps in series with all seven Not gates with their charge states constantly in motion so that would be a tough nut to crack on my end. I am almost finished drawing the circuit.
