Hackaday.io Hackaday.io
Recently Updated Most Likes Newest Project Lists
Courses Tutorials Events Hackerspaces Profiles Hackaday.com Tindie Marketplace
Sign up Log in
Light Dice
Light Logic learns to roll
Dr. CockroachDr. Cockroach
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
4 comments
1 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 3
    • View all
  • Instructions 0
  • Discussion 4
View Gallery
390
4
1
2
Team (1)
  • Dr. CockroachDr. Cockroach
Join this project's team
hardware
ongoing project
light logic vactrol led LDR photo resistor ring Oscillator
Related lists
Featured Projects
Featured Projects on Hackaday.io
This project was created on 02/10/2022 and last updated a year ago.
Description
Throwing dice or at least one die using Light Logic
The circuit uses a seven step ring oscillator, six latches, four Nand gates, one Not gate and the Die display.
Project Logs
Collapse
  • Light Dice - How it all works
    Dr. Cockroach • 02/11/2022 at 11:45 • 0 comments
  • Enhanced Die
    Dr. Cockroach • 02/10/2022 at 17:16 • 0 comments
    Added a few more red leds to the display and now it looks much better.
  • Let the good times roll
    Dr. Cockroach • 02/10/2022 at 00:28 • 0 comments
    The challenge for me was to take Light Logic and come up with a circuit that would allow me to roll dice or in this case a single die.
    I will post the circuit once I draw up a clear version.
View all 3 project logs
Log In/Sign up to comment
Sign up with Github
OR
Dr. Cockroach wrote 02/12/2022 at 10:11 • point
Yup, let the good times roll ;-)
Starhawk wrote 02/12/2022 at 02:52 • point
I'd say 'this rocks' but you've already said it rolls, and I don't want to contradict you there.
Dr. Cockroach wrote 02/12/2022 at 09:41 • point
Starhawk wrote 02/12/2022 at 10:05 • point
Then again... both is good! Hey, maybe you're on your way to bein an electronic Elvis in your own right... I can sing to that!
Hackaday Prize 2019
Using a LED/LDR pair to form inverting Photonic logic gates. The entire Boolean logic set handled by resistors and diodes! Who'd'a thunk
Project Owner Contributor
LIGHT LOGIC - HIC SVNT DRACONES
Just a little electronic sculpture using Light Logic
Hypnotic Lights
A small light sculpture
Spiral
Tauno ErikTauno Erik
Out of its cage and set free !
Light Logic - Diode Resistor Logic out of its cage
Going up?
© 2023 Hackaday
Yes, delete it Cancel
You are about to report the project "Light Dice", please tell us the reason.
Send message
Remove Member
