building the micro geared motor
A project log for AKUROBATTO
A clock that flips like an acrobat
ekaggrat-singh-kalsiekaggrat singh kalsi 02/14/2022 at 13:230 Comments
The biggest challenge was to get a small stepper motor with enough torque which could fit in small space. I did not use a hobby servo as those things don't have very accurate position sensors and they cannot do a full 360 turn . Also i experimented with small geared stepper but most couldn't fit into the tight space of the gears where useless after a few high torque runs. So i combined a 15 and 20 mm stepper with a servo gearbox.
