Story
With each passing year, the issue of food waste becomes more acute for the environment. A recent Food Waste Index Report by the United Nations Environment Program (UNEP) showed that, on average, consumers waste almost a billion tons of food per year (or 17 percent of all food purchased): https://www.unep.org/resources/report/unep-food-waste-index-report-2021
The fact that people produce more food than they consume has significant negative consequences. For example, an estimated 8-10% of global greenhouse gas emissions come from unused food. On the contrary, reducing food waste will help to reduce greenhouse gas emissions and global pollution, as well as increase food availability for countries that suffer from hunger.
This situation suggests that in the near future, we will need to focus not on scaling food production, but on timely quality control so that fresh products can be sold and consumed. To fix the current situation, humanity will need smarter user-friendly technologies that can help them monitor product quality in real-time.
In this piece, I’ll explain an easy way to check food quality that can be implemented in an average store, and even in your own fridge. And the best part - it’s not rocket science at all!
Introduction:
Recently, I conducted a simple experiment, and I would like to share it with you, as I strongly believe that such practical solutions can make a great difference in solving global problems. Baby steps on the way to global good.
My idea is to use the Tiny Machine Learning approach to forecast whether food is fresh or spoiled based on the data from gas sensors. I conducted my experiment with the use of 7 gas sensors.
In my tutorial, you will learn how you can automatically create a super tiny machine learning model, embed it into a sensor’s microcontroller, and check food quality with it.
So let’s get it started!
Procedure:
Step 1: Create a TinyML model with Neuton
Create a new solution “Food Quality” on the Neuton platform, and upload the training dataset containing signals for food quality, labeled for two classes (fresh and spoiled). My dataset contained 784 rows.
Then, select the target (Label) and target metric (Accuracy), also enabling the Tiny Machine Learning mode. Additionally, select the 8-bit depth for calculations without float data types and click “Start Training”.
The model will be ready in several minutes. Next, download the model.
Step 2: Create the microcontroller’s firmware
Download an example: https://github.com/Neuton-tinyML/arduino-example
Project Description
The project contains:
  • code for receiving a dataset via USB-UART serial port,
  • prediction fulfillment,
  • results indication,
  • code for measuring prediction time.
The main sketch file “arduino-tiny-ml-neuton.ino” has functions for processing data packets.
The main process goes on in the user_app.c file:
static NeuralNet neuralNet = { 0 };
extern const unsigned char model_bin[];
extern const unsigned int model_bin_len;
uint8_t app_init()
return (ERR_NO_ERROR != CalculatorInit(&neuralNet, NULL));
inline Err CalculatorOnInit(NeuralNet* neuralNet)
memUsage += sizeof(*neuralNet);
app_reset();
timer_init();
return CalculatorLoadFromMemory(neuralNet, model_bin, model_bin_len, 0);
Here, create an object NeuralNet and call a function for loading the model located in the file model.c
The model is now ready to make predictions. For this, you need to call the CalculatorRunInference function by transferring a float array of size neuralNet.inputsDim to it.
The last value is BIAS and should be 1.
inline float* app_run_inference(float* sample, uint32_t size_in, uint32_t *size_out)
if (!sample || !size_out)
return NULL;
if (size_in / sizeof(float) != app_inputs_size())
return NULL;
*size_out = sizeof(float) * neuralNet.outputsDim;
if (app.reverseByteOrder)
