ATTiny3226 led dot matrix driver board
An ATTINY3226 dot matrix driver board for the LTP-305HR LED matrix chip, using Arduino.
Public Chat
Beta-Testers --> Henry Knoepfle, Benjamin Williamson. These are chainable boards thru the I2C bus, Have a 'scalable' LCD display, scrolling, or wire up as a 'TIL311' emulator.
Just got a notice from Digi-Key that the LTP-305HR matrix chip has officially become obsolete! So this project has now officially become RETRO!
rev1's are available.......
working on getting rev2 built and tested, ( picture with vqfn package, on the left ).
Simplistic Arduino Example files on GitHub ----> https://github.com/haroldmoore/Led-Dot-Matrix-display-board/tree/main
TIL311 Emulator mode is now working --- >
files on github ----- >  https://github.com/haroldmoore/Led-Dot-Matrix-display-board/blob/main/matrixencoder1.zip
I found  WAY better encoder control firmware on github, here it
is :
https://github.com/haroldmoore/Led-Dot-Matrix-display-board/blob/main/custom_encoder.zip
------------------------------------------------------------------------------------------------------------------------------------- The REV 2's are in!  The REV 2's are in!!  here is a short video ----> https://youtu.be/sF_6io8nx4A
Here is how the vqfn sits for soldering, looks like the three vias in the middle will have to be moved, so I can have a "lower fit", not to mention shorting out on the chips center pad!  So all is not lost, just have to re-spin some newer gerber files.
The socket pins will fit perfectly! Then when people wear out the obsolete, and extinct 5x7 dot matrix led chips, they can plug in a brand new one from EBAY.......
Soldering the small 20 pin 3mmX3mm VQFN is possible, here is a small video showing that it is in fact possible, if you have a small fan to blow away the solder fumes, and some magnification equipment, ( a loupe ) :-)    ----- >  https://youtu.be/VPb-hWagqgQ
Rev 2's are working OK, minor change to the control lines:
//################## Decimal Point Control ######################
//************************** rev1 *******************************
//int rowPins[7] = {1, 14, 2, 3, 13, 12, 11}; //-program ROW pins
//int colPins[6] = {5, 4, 0, 10, 16, 15 }; //-program COLUMN pins
//************************** rev2 *******************************
int rowPins[7] = {1, 16, 2, 3, 13, 12, 11};   //-program ROW pins
int colPins[6] = {5, 4, 0, 10, 15, 14 };   //-program COLUMN pins
I'll make a video of the versions ( VQFN / SOIC ) , ( new / old ) here shortly.
https://youtu.be/t8oCzLpNPZM
Time to get working on 'Rev 3' with an 0202 led matrix plug-in board, since the
display chips have become obsolete, in the mean time been seeing how the
RGB strips program up for quick SIGNS, ---> https://youtu.be/oNyM8KGrFpE
Here is a short video using the smaller REV2 VQFN 5x7 matrix display boards  in a custom CLOCK application :   https://youtu.be/7QRXrlKybig
A more complete logger :
It appears that the carrier board with the 202 led's have been bumped down in priority in favor of the
encoder carrier board:
Ok, now that the ATTINY3226 I2C encoder pcb is working, I can get back to making the rev 3 matrix display pcb with 0603 leds. :-)
View project log
haroldmoore016 wrote 12/25/2022 at 01:35 point
Wish the files section files were removeable, real old stuff! I'll put the newest files up with a
Git Hub link!
morgan wrote 12/25/2022 at 02:46 point
you can but the UI is odd, at the bottom of the Files section there is an Edit Files button, from that next page you can delete.
haroldmoore016 wrote 12/25/2022 at 18:46 point
Thanks! hard to see the 'YES' after hitting the 'X'  :-)
haroldmoore016 wrote 02/17/2022 at 15:08 point
Look at the You Tube links!
