4 Bit Counter
A project log for Serial Transmitter Using Discrete Parts
An asynchronous serial transmitter using only mosfets, resistors, capacitors, and diodes as building blocks.
eric-ljungquistEric Ljungquist 02/21/2022 at 07:290 Comments
The above video show to early testing of the counter. I have it hooked up to a 555 timer and the outputs of each counter stage are connected to an LED. The LED's show the circuit count up in binary as expected.
4 Bit Counter in CircuitJS
kl;kj;
jk;kj;
