Prototyping
02/23/2022 at 21:56 • 0 commentsTo avoid a lot of hand-wiring, I bought an 8-bit ISA bus board from eBay. This reduces the effort to interfacing an STEbus slave prototyping card to an 8-bit ISA bus connector.
There is some TTL and a PAL16L8 doing some address decoding logic.
The RS232 buffers are 75185 chips.
The UART crystal is 3.6864 MHz, and is halved to drive the 16C552. This limits the maximum baud rate to 115200 baud.I could solder wires directly to the edge connector, but fitting an ISA bus socket would allow me to experiment with other ISA bus cards without soldering and desoldering. So I bought some sockets.
Most of the signals are address, data and power lines. The remaining signals are 8088 style, and it should not be hard to create them from the STEbus signals.
Choice of chip
02/23/2022 at 21:03 • 0 commentsMany chip manufacturers quickly rushed to make high-integration chips for the IBM PC market. Serial ports, parallel ports, game ports, floppy drive and hard drive interfaces. Any combination of some or all of these functions. When the ISA bus became obsolete, the chip manufacturers left the market just as quick.
For example, I have an ISA bus multi-I/O card with serial, parallel, floppy and hard drive interfaces provided by a single chip - the Acer M5105. Interesting but not only can I not buy one on eBay, I can't even find the data sheet. No point in designing projects that use unobtainable chips.
However, chips that provide PC-compatible serial interfaces are still made. They are pretty capable devices, and there had been no market demand to drive the evolution of devices like the 6850, SIO, and so on.
The 16C552 is one of the few chips still made that have an LPT port. Even if you don't have a Centronics printer to talk to, an LPT port can provide a little parallel I/O to play with.
At the time of writing, the 16C552 is available from Mouser and Digikey.
Keith
