The design process
A project log for 2022 HDP 4 - Climate Resilient Communities
Air quality sensor systems for urban bodies of water, so that the population can avoid potentially dangerous exposure
giovanniGiovanni 06/20/2022 at 20:130 Comments
The design for this device was heavily influenced by function. There are a few critical considerations, among them:
I have seen many units with the solar panels in a separated component. However, I wanted to make this one as portable and sturdy as possible, so I went for the "uni-body". An additional advantage is that the oversized dimensions of the solar panel allow for a roomie interior, which helps air circulation for the sensors.
Before working on any sketches, I wanted to explore a bit the possible array inside. We have a main board with a bunch of sub-boards, a big battery, some cables, and that's it.
Once I had the ideal array for function and production, time to sketch some possibilities. These were some of the first sketches:
A very important part is the Stevenson screen, which is a specific "enclosure to meteorological instruments against precipitation and direct heat radiation from outside sources, while still allowing air to circulate freely around them". So, adding the blinds to the enclosure was the next step:
The design looked pretty doable, so I quickly moved on to the development stage.
