Popped out another one with the scratching head as only 2 pieces instead of 3. The trick with the scratching head is 5mm retraction & no extra prime. Everything else continues to work best with 3mm retraction & 1mm extra prime.
It takes a tricky blender boolean to get the alignment notch to come out.
It became clear that a radically different design is needed for bed. It can't have the head scratcher end. It needs to be a lower profile. It needs to be less aggressive. A more traditional design might be needed. So far, the mark 1 lion paw has been the best solution.
lion mclionhead
