[L] Silkscreen Issues
A project log for Tetrinsic [gd0041]
A motorised fader that is continuous, pressure sensitive, haptic and water resistant.
kelvinakelvinA • 06/24/2023 at 21:12•0 Comments
So I noticed that one of the components were rotated the wrong way:
I thought "I would've been able to see and avoid this problem if I could actually see where the pads were.
Seems that was the only issue, but I thought I should look into this silkscreen issue.
The actual silkscreen is a mess...
...so I thought of making a new layer entirely:
I moved my rectangle to the new layer and tried to set up the postprocessor, but it doesn't seem to have worked:
It also wasn't showing correctly in the CAM preview.
I then found this in the Layer Sets Manager, and I removed tPlace and tNames and added OverSilk. The preview now looks as intended, at least.
Still doesn't look correct on JLC's site though.
