Slowly building up the confidence to, realistically, start redesigning the concept from the ground up again. It's moments like these when I seriously consider if I should put even more time into Fusion 360 models or if I should try and jump ship.A project log for Tetent [gd0090]
A water resistant, 300WPM input peripheral for end-to-end workflows.
