E3D V6 Hotend Issues
A project log for Ender 3 Artifex Edition
Dual Z-Axis Linear Rail & Drive. Dual Gear Direct Drive. X & Y Linear Rails. E3D V6 Hot End. All metal. All blue. All sexy.
g0ldenerdg0ldenerd 03/19/2022 at 17:500 Comments
I have received the hotend setup and the shroud I had originally chosen for the project. The shroud was 1/4" too thick to fit with the metal clamp system. I will need to design a shroud for this project. For now, I will be using the Haldis 3D J6 hotend I had been
