SecSavr Sublime [gd0036]
An FDM 3D printer that I described as "The FULL Coverage, Extended X, Pro Max, Ultramatrix Solution".
Public Chat
This is not a printer project that tries to see how many features you can put into an FDM printer. This is just a normal 3D printer, doing normal things... if it was made in the year 2026.
I've come to the conclusion that designing, testing and tweaking a new printer takes a long time, especially if upgrades are involved, so I've decided to instead go with an "[insert feature] ready" approach to fufill the CostApp, SpaceApp and TimeApp.
As of Sep 10th 2022, the project has been cancelled due to [gd0105] theoretically being better in every way other than eye-candy.
Media
Music I mentally associate with this project
Ashton Edminster - Something Different:
Mainly the "Something different, don't know what to call it" line because this printer isn't a conventional FFF printer and this project was just called "SecSavr" for most of its lifetime because I couldn't think of a name for this printer specifically. "SecSavr" is a non-existant 3D printer brand name I thought up, so this situation is like Sony coming out and announcing that their new product is "The Sony".
Navigation
The title tag system is explained here, and the table is updated when a change occurs. Notable logs have bold L# text.
L1
[A] If I made an ad, this would be the background music:
L2
[A] Project progress before hackaday page
L3
[P] = Parts received
- CHC Pro, high flow heatbreak, airbrush nozzle, 42.4mm steel tubes
L4
[R] Finding other projects
L5
[R] Enclosure Material
L6
[R] Information for galvanised pipe + key clamps
L7
[R] Enclosure design considerations
L8
[M] Current Modelling Progress
L9
[P]
- Constant force spring (that I hurt myself opening), low cost 608 bearings
L10
[P]
- 32mm long "Lengthen" nozzles, S6609 stepper drivers,
- T-slots, volcano nozzle adapters
- Threaded aluminium spacers, motor mount plates
- Springs, 15mm magnets
L11
[R] Enclosure material considerations so far
L12
[R] Multiwall Polycarbonate
L13
[R] Toolchanging printers with shared extruder motors
L14
[R] Similar Project Research
L15
[P]
- M8 fixings
L16
[M] - Test linear carriage
L17
[X][P] Tube Linear Carriage Success
L18
[M] - Enclosure Initial Concept
L19
[T] Print Material?
L20
[M] Room
L21
[T] Dust (and other milling) Concerns
L22
[T] Hotend
L23
[M][T] 8 Entire Millimetres
L24
[X] Testing the GC6609 / S6609 Stepper Drivers
L25
[P] Octopus Pro
L26
[X] Hotend Testing
L27
[A] AIO II Issues
L28
[A] Octopus Pro
L29
[A] Current Motor Layout Plan
L30
[M] Enclosure: SecSavr SleepCinema [gd0099]
L31
[T] Electronic bed levelling
L32
[X] Extruder issues
L33
[X] Initial extruder tests
L34
[T] SleepCinema design
L35
[B][T] Frame BOM
L36
[R] Searching GitHub
L37
[M] Clamp 116 and Fusion 360 Housekeeping
L38
[M] Bed and start of frame
L39
[M] Clamp 161
L40
[M] Z Axis Tubes
L41
[T] Gantry Name: SecSavr Slab?
L42
[M] Tool Axis Tubes
L43
[M] Tube Carriages
L44
[T] Bed and Tool Calibration
L45
[T] Bed Holding Medium
L46
[M] Z Slider
L47
[M] Y Slider
L48
[T] Counterbalancing Z Axis
L49
[R] Spring Balancer
L50
[T] Frame: SecSavr CeilingSingle
L51
[T] Octopus Pro Price
L52
[T] Spider V1.1?
L53
[M] Sketching Tool Bar and Sliders
L54
[M] SleepCinema Panel Adjustment
L55
[R] 10 Axis Printer
L56
[T] Octopus Pro + EXP MOT and the Tool Bar
L57
[T] Tubes, Fabrication and Milling
L58
[R] Computer vision for tool offset calibration
L59
[R] Auto PaintShop
L60
[R] Threadless Screw
L61
[R] Ribbon Nozzle
L62
[M] Branding
L63
[T] Test Driven Development?
L64
[G]Tapping the 30mm hex spacers
L65
[T] SecSavr Slight Heatsink
L66
[M][E1] New heatskink strategy
L67
[M][T] VolcanoV2 instead of CHC Pro
L68
[M] Swapping extruder and magnet locations
L69
[M] SecSavr Spindle concept
- And idea of 2 in 1 out support
L70
[P][M] Cheap glass found on Ebay
L71
[R] Worm gear for V axis?
L72
[M] Camera Mirror
L73
[T] Motherboard on a moving axis?
L74
[T] Tool Pogo Pins
L75
[R] Bigtreetech Manta M8P
L76
[M] 868 Pogo Connectors
L77
[M] Tool Plate with the 868 pogo connector
L78
[M][R] Slime Bearing
L79
[R] Tube printing
L80
[M] The New Y Axis Slider
L81
[M] Z Slider Cover
L82
[M] Slime branding and SecSavr name?
L83
[A] Project rename to SecSavr Sublime
L84
[M] Importing beds
L85
[M] X Axis Slider Concept
L86
[M] Continuing X slider and finding a new bowden route
L87
[M] Alignment tweaks
L88
[M] X Arm and Tool Bar
L89
[M] SecSavr SuperSpindle
L90
[T] Pogo Pinout
L91
[T] Multiple use cases for the blower bowden tube
L92
[T] 352 Bearings Needed
L93
[M] SleepCinema tweaks
L94
[T] SecSavr Sublime Already Out Of Date?!!?
L95
[A] Project Frozen
L96
[R] Continuous tape reinforcement
L97
[P] BTT CB1
L98
[A] Uploaded v72 .step file
L99
[T] Idle thoughts
Preface
[2022 - May 18] (and tweaked 2024 - Jan 14)
Short for SecondSavr (as in, saving seconds of time), this...
SecSavr SleepCinema v72.step
Very incomplete but available under the Creative Commons Attribution 4.0 International License.
step - 25.31 MB - 07/31/2022 at 02:01
Download
  • [T] Idle thoughts
    kelvinA10/09/2022 at 17:50 3 comments
    This is a place to put any discoveries I find, if anyone was looking at this project for inspiration.
  • [A] Uploaded v72 .step file
    kelvinA07/31/2022 at 02:09 0 comments
    The CAD is still very much incomplete, but I also dislike when someone says they intend to upload the CAD data, but only after they've "cleaned it up".
  • [P] BTT CB1
    kelvinA07/23/2022 at 12:32 0 comments
    So I was able to get on the limited edition CB1 drop ($10 price) and, looking at the order speeds in the first hour, I seemed to be the only one that was treating this like a GPU stock drop. I went in with the minimum to grab being 2 (for each Sublime) and 4 ideally (Suspense and a spare) but there was a 1 per customer blockade. I bought 1 immediately, tossed and turned for maybe 20 minutes, and made a second AliExpress account to get another one. Sometime (maybe a day) later I was just scrolling around and the $10 CB1 was back in stock. Strange. There's 2 of them though. And I can check out with both of them? Ok then!
    Wow this board is TINY. Seems to also come with an antenna with adhesive.
    I wasn't expecting them to be this small. £23.50 is an expected price considering it's like a CB4 version of the Orange Pi Zero 2, but I'd like to imagine how versatile this could've been if their $19.90 (£17.47) lesser early bird price was the consistent price. What about $15??
  • [R] Continuous tape reinforcement
    kelvinA07/18/2022 at 21:10 0 comments
    One of the issues I'm finding with the continuous fibre feature implementation is that the fibres on Aliexpress like basalt and carbon are sold in something that more resembles a ribbon than thread.
    While scrolling around, reading what industrial 3d printing companies have been getting up to, I found out that there's some rivalry between Desktop Metal and Markforged, and that Desktop Metal was making a continuous fibre 3D printer that could compete with Markforged's offering.
    Seems that Desktop Metal has engineered a way to use the fibre's ribbon stock to their advantage.
    It very much seems to be a 2 tool toolchanger with the fibre tool being able to rotate 90 degrees, which would be able to get the fibre in any orientation. This reminds me of the rotating nozzle I found earlier.
    It likely uses a heated roller (that seems spring loaded in the animation) to apply the continuous fibre.
    Why is this a nice solution? For starters, I believe that it could be easier to do this instead of accurately aligning a thread under a nozzle to print a fibre infused extrusion line. Another thing is that it sounds much easier to feed to the Slime, easier to cut and I can use the free extruder gear as the 6th axis, unlocking the ability to have fibre reinforced prints not just on the Rotary Bed, but on all the beds like the Long Bed (because parts that use this bed would likely benefit the most from fibre reinforcement) and 5 axis support.
    Then there's these 2 graphs:
    The grey dot is likely Markforge's flagship continuous carbon fibre:
    The carbon fibre tape is nearly 2x the tensile strength and is 2x the modulus. I'm more interested in the cheaper glass fibre tape (for which basalt should be a bit better). 30GPa modulus and a strength inbetween 800 and 1000MPa, according to Markforge's datasheet:
    I just hope that I can just press the basalt fibre into a printed channel similar to using a soldering iron to embed steel wire into a print. If that plan fails, I'd imagine extruding a thin bead of filament on one side of the fibre for a stronger bond between the fibre and the bottom of the channel could provide a solution.
  • [A] Project Frozen
    kelvinA07/18/2022 at 03:55 0 comments
    Frozen due to the following reasons:
    • Diverting time to the #SecSavr Suspense [gd0105], #Teti [gd0022] and #Tetent [gd0090]. If I try and go for everything, I'll probably end up with nothing to show for it.
    • Other than continuous fibre, gd0105 could potentially fufill my 3D printing needs in a smaller footprint and lower cost, as well as higher speed for multiple parts (the brand is called "Second Saver" after all).
    • gd0105 and the previous log made me realise just how much more stuff there is to model for gd0036, and I'd like to wait for #enSweepen [gd0096] to model all that.
    • I'm out of my student accomodation for the next 2 months, where gd0036 is intended to be installed. I can make gd0105 outside of the SleepCinema, but can't really say the same thing for gd0036 (back to the "smaller footprint" thing I wrote earlier)
    I remember I had a slight worry all the way back when I was starting out with gd0036 (in 2021) and thinking to myself "You know I'm not the fastest CAD modeller out there. What if some fancy technology finally comes out in 2022 and makes my FDM printer archaic? I feel like some resin printer could do that if it played its cards right." (similar to buying a 2080ti a month before the 3070). Seems that that time is now. I still can't see how someone or some company before BCN3D hasn't created this kind of film lamination MSLA/DLP 3d printer though. Then again, there doesn't seem to be much research other than on the material side for making resin printers safer to use or cutting out post processing steps.
    In other news, I just found out that BCN3D is planning to ship printers in Spring 2023 (as I expected) but only 20 of them (kinda strange, especially since they have over 500 signups and I thought the printers were already ready for mass adoption) so if I could obtain a future where I have a working SecSavr Suspense (as currently invisioned) before then, I'd have a next generation 3D printer before the big companies and it'll be something closer to a second gen version already.
  • [T] SecSavr Sublime Already Out Of Date?!!?
    kelvinA07/16/2022 at 14:34 0 comments
    This kinda feels like a "Suffering From Success" kind of thing, but I've been working on the #SecSavr Suspense [gd0105] and returning to my original thought I had a few days after watching BCN3D's VLM video: Is gd0036 redundant/outdated before arival?
    Now you may be wondering how a 5 axis, IDEXY, 10 toolchanger, 16 filament, modular bed (with infinite Y belt option), continuous fibre, airtight enclosed, additive and hopefully subtractive 3D printer could possibly risk being old tech already. I'll answer that.
    The SecSavr Suspense's current optimistic solution.
    I've already mentioned my concerns when it comes to print speeds in this log I just wrote. Sure the Suspense won't be milling PCBs, can only fit 8 materials instead of 16 and probably won't see continuous fibre support, but for additive manufacturing, it has the potential to do what I want out of a printer and has less unknowns with it.
    Suspense Unknowns:
    1. Is there a semi-flexible material that can remove a thin layer of uncured resin and be cleaned before the next layer?
    2. Can a thin (around 0.1mm) layer of resin be deposited onto a film like PET?
    3. Can I program a slicer for it?
    Sublime Unknowns:
    1. Can I program a slicer with the below functionality?
      1. 5 Axis
      2. Fully independent dual extruder printing
      3. Continuous fibre pathing
      4. Milling
    2. Will the #SecSavr Select [gd0091] be reliable enough?
    3. Will the rotary axes be stiff enough?
    4. Will the continuous fibre syringe nozzle be aligned well enough to work?
    5. Is there a suitable belt bed material?
    6. Will the magnetic tool system be strong enough for the SecSavr Spindle?
    Shared Unknowns:
    1. Can I make an airtight enclosure with activated carbon (and HEPA for Sublime) filter?
    2. Can I cool the electronics?
    3. What's the max speed acheivable?
    Moving on, there's material properties. SLA printers can create thermoset polymers, VLM can use less brittle resins and SLA prints are more isotropic, meaning that some parts can be angled to fit where an FDM printer would ideally need a larger bed. Colour choice could also be another win for the Suspense.
    With print volume, there's limitations on the Y length (the longest side of the LCD, and maybe the cleaning roller), but as of now, I can't see much limitation for the X or Z height. Gravity is pushing the part towards the bed and not away from it, and in both cases the only thing that really changes is the length of linear rails, ballscrews, roller and the unheated bed. Adding to the fact that resin printers don't need a heated chamber either and the Suspense has serious power savings over the Sublime.
    Right now, it's probably too early to call anything and I'm probably just speedrunning through the hype cycle with the new and emerging technology called VLM, but I'm on this rollercoaster now so I might as well enjoy it.
  • [M] SleepCinema tweaks
    kelvinA07/14/2022 at 04:40 0 comments
    Due to developments with the SecSavr Suspense project, I've moved the Z axis beams closer to the sides of the SleepCinema to make room. I also removed all the extra Slights from the Tool Bar to improve performance.
  • [T] 352 Bearings Needed
    kelvinA07/09/2022 at 18:32 0 comments
    I was thinking about how the specific implementation of the double belt, wondering if the round profile of the HDT 3M belts would even agree to do what I want to use them for, when I realised that I'd need 8 bearings for each slider that used the double belts. I could probably cut that to 4 if I printed out some kind of wheel, but the total amount of bearings still exceeds the 200 I have now and I don't have that much space in the sliders.
    I did the calculations of the main bearings and I got 224 bearings for both Sublimes. I feel like I must've accidentally only calculated for one set in the past. Anyway, it's not like I want to take a chance on a 3rd set of bargain bin bearings that would probably go out of stock forever in the coming months, especially since I'm trying to get some sort of decent system everywhere else (you know, like dual 15mm 3M belts). I don't want the weakest link to be all the bearings, as that's what moves the 3 main axes.
    I also didn't know that the seal gap wasn't supposed to be so large. To adress the points about future availability and get something that probably runs better, I found these 608ZZ's on AliExpress.
    No idea about quality, but ZZ bearings allegedly run smoother than 2RS as the rubber seal isn't in contact with the wheels. The ZZ's probably would have a better seal that the RSs I have now. I'm thinking of using the ZZ's for the sliders, and some of the 200 RS bearings will be used in the sliders to squish the double belts together.
  • [E1][T] Multiple use cases for the blower bowden tube
    kelvinA07/06/2022 at 22:04 1 comment
    I reluctantly decided to go for a bowden blower a while ago since I wanted to reduce length. Later, I thought that I could now implement to vacuum for the Spindle, and now I've realised that I could use it as a pathway to send 2.85mm filament down to a modified Slight extruder tool, but more importantly, to move pellets.
    It's probably simpler to have some kind of pellet feeder on the Tool Bar, now that I think about it, but the idea was to have a dual tool wide pellet extrusion tool and have 1 bowden blowing cool air to the part and the other blowing pellets.
    Yeah it's probably better to just have a pellet refueler on the Tool Bar, high extruder costs and low availability (if purchaser is not a company) nonwithstanding. I did find this awesome pellet extruder that shockingly retracts so well, it sucks filament back INTO the nozzle! I didn't think pellet extruders would somehow get better retract performance than filament ones.
  • [T] Pogo Pinout
    kelvinA07/06/2022 at 09:30 0 comments
    I've been thinking about the specific pogo connector pinout to see if I can find a solution that won't damage components if the wrong tool was installed. With an 8 channel relay, each Slime will have:
    1. 24V or Mot1*
    2. Toggled GND or Mot1*
    3. GND or CAN1
    4. Thermistor or CAN2
    *Mot2 will be on the other slime.
    The first option is the one selected when the relay signal is 0. Pins 1-2 will share a signal pin, as will pins 3-4.
    The reasons for the pinout choice:
    • Say that the Spindle is expected but the Slight is plugged in. A voltage of +/-36V is applied through Mot1/2. The heater, connected to pins 1 and 2 will see a potential difference of 0V, as will the CANbus tool.
    • Then there's the opposite situation, where the Slight is expected but a Spindle is plugged in.
      • If a thermistor is used on the Spindle, then the mismatch won't be detectable and pins 1 and 2 will be shorted.
        • The Manta M8P seems to have harder-to-replace fuses than the Octopus Pro, so inline replacable fuses would be used instead. Alternatively, since there's not many mentions of installing a thermistor with a spindle, it can be ommited and a MINTEMP error will occur in this scenario.
        • Expecting a CANbus tool and receiveng a Spindle will result in a short, so a 9A fuse would be needed anyway.
      • Wait a second. What about a diode from Pin2 -> Pin1 inside the Spindle? The Spindle motor will be connected to Pin1 and take current from both pins when operating normally, but 24V to ToggleGND will have a large resistance.
    • The next scenario is expecting a Slight but a CANbus tool is connected. The resistance over pins 3 and 4 should be 120 ohms, which seems lower than what a thermistor would have at 300C printing temperatures [reference]. A MAXTEMP error should occur.
    • The last scenario is expecting a CANbus tool but a Slight is connected. CAN1 will be grounded and CAN2 would be a 4.7 kΩ pullup to 5V. CAN will tolerate one of the lines being connected to ground [reference].
View all 99 project logs
