There's no such thing as a 42.4 to 33.7mm version of the 161 clamp, so they're the same thickness as the rest of the frame, even if it could be considered overspecked for this use case.
Modelling time: About 40 mins
A project log for SecSavr [gd0036]
A 3D printer that I describe as "The FULL Coverage, Extended X, Pro Max, Ultramatrix Solution".
