[M] Z Slider
A project log for SecSavr [gd0036]
A 3D printer that I describe as "The FULL Coverage, Extended X, Pro Max, Ultramatrix Solution".
kelvinAkelvinA 7 days ago0 Comments
I feel kind of lost since this is the moment when I start thinking of the actual details that turns an idea into something that would actually work, but I'm currently modelling the Z Slider. I'm doing a bit of a "Merge/Insertion Sort" like approach when it comes to housekeeping.
I'm using a 12 sided polygon as the clamp interface between the Y axis tube and the Z axis slider. This gives some tolerance in the design.
I originally thought of having the clamps oriented the opposite way, but I'm thinking that the design can get a higher space utilisation this way.
