[M] SleepCinema Panel Adjustment
A project log for SecSavr Sublime [gd0036]
An FDM 3D printer that I described as "The FULL Coverage, Extended X, Pro Max, Ultramatrix Solution".
kelvinakelvinA 05/21/2022 at 19:040 Comments
I thought about this redesign a week ago, and have just rendered it. The doors are still on the wide white side, but they're now opal. Both short sides are now bronze polycarbonate. I've also added LED's into the small double bed section.
The CeilingSingle would look similar to this, just that the door is now the bronze side, the white sides is about half length and the back "new long side" is opal. I think it would look pretty professional.
