[R] Ribbon Nozzle
A project log for SecSavr Sublime [gd0036]
An FDM 3D printer that I described as "The FULL Coverage, Extended X, Pro Max, Ultramatrix Solution".
kelvinakelvinA 06/10/2022 at 07:330 Comments
http://sculpman.com/product
This company makes a nozzle that converts 2.85mm filament into a ribbon which can adjust from 0 - 10mm. The bad news is that they only want to work with companies, as told in their Contact page.
The SecSavr and the #Polar Cartesian Hybrid with "rotating nozzle" (where I found out about this nozzle) wouldn't need the rotating axis on the hotend, but the creation of the nozzle is out of my element. My uni made a hotend that prints tubes that they just showed off at TCT 360 (though I'm sure more people saw the hangprinter drone) so the probabilityof obtaining a solution for a ribbon nozzle is low but not 0.
