[M] 868 Pogo Connectors
A project log for SecSavr Sublime [gd0036]
An FDM 3D printer that I described as "The FULL Coverage, Extended X, Pro Max, Ultramatrix Solution".
kelvinakelvinA 07/02/2022 at 18:460 Comments
Timed myself and it took 52 minutes to model, another 5ish to make the design parametric and probably another 10 to upload to GrabCAD.
I'm planning to use the 868-22-004-00-011101 and 868-10-004-00-012000 connectors.
