[M] Importing beds
A project log for SecSavr Sublime [gd0036]
An FDM 3D printer that I described as "The FULL Coverage, Extended X, Pro Max, Ultramatrix Solution".
kelvinakelvinA 07/05/2022 at 03:210 Comments
Good thing that I found that 35cm glass because it looks like I'd actually be able to use most of the circular diameter. I'm planning on having the bed rotate so that it can reach the entire area.
Unexpectedly, it looks like I might actually be able to get both Slimes to reach over the length of the Long Bed.
