[M] Z Axis Tubes
A project log for SecSavr Sublime [gd0036]
An FDM 3D printer that I described as "The FULL Coverage, Extended X, Pro Max, Ultramatrix Solution".
kelvinakelvinA 05/06/2022 at 19:020 Comments
It's looking awfully tight for the dual set of Z axes. I intend for the Slime [gd0088] harnesses to actually be in that centre area between the sets of 4 tubes but things could get a bit dicey.
There's about 10mm of clearance for the M16 grub allen key.
