[T] Lego compatible supports
A project log for SecSavr Sol^2 [gd0045]
I've wanted to make a slicer since 2019. The SecSavr Suspense [gd0105] presented a solid reason.
kelvinakelvinA 07/17/2022 at 00:030 Comments
This is an idea intended for the #SecSavr Suspense [gd0105].
Why have a seemingly useless lattice structure of support material for prints when, with a bit of dissolvable material, they can be lego compatible blocks? This will cut down on support that goes into the bin, make it easier to break away the supports around the model and increase lego brick bin quantities on the side or potentially sold on ebay, recouperating some resin costs.
