Originally a program for my 6th Form coursework, this interval timer aims to allow a CPU-scheduler-like approach to IRL multitasking, for when one feels like they want to do a bunch of different tasks at the same time.
Task blocks are intended to be allocated 3 - 6 minutes, with rest blocks (intended approx 30s) inbetween to allow oneself to switch to the new task. This hopefully allows one to better predict how long a specific task would take, and/or be completing another task while subconsiously solving a hurdle encountered in the previous task or plan exactly what next steps need to be performed.
The yellow blocks are for transitions. The first of these blocks can be used as a warmup (because that's what its for) but it can also be a timer to start the next set of blocks after having a break. For me, it seems that I can only get my break down to 30 minutes if I've prepared in advanced, and lunch breaks usually are 60 - 90 minutes.
The purple blocks are for brain-off time. You may have heard the phrase "the mind is a muscle"? This is the rest period for such muscle. Things I've done in this time:
The main thing to do is sleep
Whilst doing so, imagne that you've actually been sleeping the entire time and all the work has been done "real-time" mentally.
The goal is to finish the entire set and think that you've just been asleep for [loop amount] number of minutes, but the stuff you needed has been done by your clone / *mental-reality character in that time.
*like "virtual reality", but powered by imagination not a GPU.
Look at something whilst slowly panning the head for 16K 480fps XDR B-Roll stock footage
Or move kind of slowly, as if you're in stock footage merged with the b-roll footage.
Example of b-roll, where the camera slowly pans to the right:
Example of person in with the b-roll, where they're slightly nodding their head in slowmo:
Get up, stretch, push ups
Evaluate progress, think about the next tasks to do or decide if you've spent too many block loops on a task.
This entire thing is like a micro Poromodo Technique, it's just that I didn't have the stamina nor time awareness for 25 or 50 minute long work sessions before a break.
Time is bundled into more managable chunks, as 60 seconds is quite short once getting into the flow. Coincidentally, each loop is 7.5 minutes long, so it means 8 loops = 1 hour. It's kinda similar to the Nether dimension in Minecraft, where 8 blocks in the Overworld = 1 block in the Nether.
Lastly, this solution abstracts time. You know about in-game currency and the psychology behind it? Similar idea here, further enhanced by my #TrueTent [gd0143] project that aims to make a temporary work area with artificial daylight to have a time-invariant seeming space.
The interval timer is great. I used it almost every week when I want to plan how long I want to be doing a task, or switching between a task and rest. Especially, working at home when you can easily get drowned in work, you can use the interval timer as a guide to say when you are resting. The interval timer is easy to install and use. The user interface is very friendly. I would like it as an app in the future and the volume between the timer needs to be higher. There is nothing else like this so a good project to develop. Thanks Kelvin for building this!
