3d printed variable capacitor
A mostly-printed variable capacitor using copper-clad pcb boards
benBen
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
A variable capacitor made with parts I had laying around. Used in a magnetic loop antenna (also made with parts I had laying around). STL files can be found https://www.thingiverse.com/thing:5263587 The two rectangle blocks on either end are print-in-place bearing blocks. The tolerances are fairly tight to keep them from wiggling - had to do some trial and error to find what worked for my printer.
