• 1
    Using Bluetooth (Python Script)
    from machine import Pin, UART
    uart = UART(0, 9600)
    led = Pin(13, Pin.OUT)
    while True:
      if uart.any() > 0:
        data = uart.read()
        print(data)
        if "on" in data:
          led.value(1)
          print('LED on \n')
          uart.write('LED on \n')
        elif "off" in data:
          led.value(0)
          print('LED off \n')
          uart.write('LED off \n')
  • 2
    Get GPS Data (Python Script)
    from machine import Pin, UART, I2C
    from ssd1306 import SSD1306_I2C
    import utime, time
    i2c=I2C(0,sda=Pin(0), scl=Pin(1), freq=400000)
    oled = SSD1306_I2C(128, 64, i2c)
    gpsModule = UART(1, baudrate=9600, tx=Pin(4), rx=Pin(5))
    print(gpsModule)
    buff = bytearray(255)
    TIMEOUT = False
    FIX_STATUS = False
    latitude = ""
    longitude = ""
    satellites = ""
    GPStime = ""
    def getGPS(gpsModule):
        global FIX_STATUS, TIMEOUT, latitude, longitude, satellites, GPStime
        timeout = time.time() + 8     while True:
            gpsModule.readline()
            buff = str(gpsModule.readline())
            parts = buff.split(',')
            if (parts[0] == "b'$GPGGA" and len(parts) == 15):
                if(parts[1] and parts[2] and parts[3] and parts[4] and parts[5] and parts[6] and parts[7]):
                    print(buff)
                    latitude = convertToDegree(parts[2])
                    if (parts[3] == 'S'):
                        latitude = -latitude
                    longitude = convertToDegree(parts[4])
                    if (parts[5] == 'W'):
                        longitude = -longitude
                    satellites = parts[7]
                    GPStime = parts[1][0:2] + ":" + parts[1][2:4] + ":" + parts[1][4:6]
                    FIX_STATUS = True
                    break
            if (time.time() > timeout):
                TIMEOUT = True
                break
            utime.sleep_ms(500)
    def convertToDegree(RawDegrees):
        RawAsFloat = float(RawDegrees)
        firstdigits = int(RawAsFloat/100)     nexttwodigits = RawAsFloat - float(firstdigits*100)
        Converted = float(firstdigits + nexttwodigits/60.0)
        Converted = '{0:.6f}'.format(Converted)     return str(Converted)
    while True:
        getGPS(gpsModule)
        if(FIX_STATUS == True):
            print("Printing GPS data...")
            print(" ")
            print("Latitude: "+latitude)
            print("Longitude: "+longitude)
            print("Satellites: " +satellites)
            print("Time: "+GPStime)
            print("----------------------")
            oled.fill(0)
            oled.text("Lat: "+latitude, 0, 0)
            oled.text("Lng: "+longitude, 0, 10)
            oled.text("Satellites: "+satellites, 0, 20)
            oled.text("Time: "+GPStime, 0, 30)
            oled.show()
            FIX_STATUS = False
        if(TIMEOUT == True):
            print("No GPS data is found.")
            TIMEOUT = False
  • 3
    Get Sensor Data from MPU6050 (Python Script)
    from imu import MPU6050
    from time import sleep
    from machine import Pin, I2C
    i2c = I2C(0, sda=Pin(0), scl=Pin(1), freq=400000)
    imu = MPU6050(i2c)
    while True:
        ax=round(imu.accel.x,2)
        ay=round(imu.accel.y,2)
        az=round(imu.accel.z,2)
        gx=round(imu.gyro.x)
        gy=round(imu.gyro.y)
        gz=round(imu.gyro.z)
        tem=round(imu.temperature,2)
        print("ax",ax,"\t","ay",ay,"\t","az",az,"\t","gx",gx,"\t","gy",gy,"\t","gz",gz,"\t","Temperature",tem,"        ",end="\r")
        sleep(0.2)
