In this log, I will try to create an automation in Home Assistant, that controls the ventilation speed in a smart way so that the indoor temperature during the summertime will not become as hot. The idea is basically to control the ventilation speed, based on this configuration:
Increase ventilation speed to level 3:
Triggers:
- Someone leaves the house (leaves a zone)
- It's 8 o'clock in the morning
The conditions that should be met:
- And: everyone is away from the zone (each smartphone is away)
- And: the actual outdoor temperature should be below 20°C
- And: time should be between 6 o'clock and 12
- And: the forecasted outdoor temperature should be more than 25°C
Actions:
- Set fan speed level to: 2 or 3
- Send a message to my phone (testing purposes)
The HA script:
- id: 'xxxxxxxxxx'
alias: Start smart ventilation
trigger:
- platform: time
at: 08:00:00
- platform: device
device_id: XXXXXXXXXXXX
domain: device_tracker
entity_id: device_tracker.marcel
type: leaves
zone: zone.home
- platform: device
entity_id: device_tracker.mywife
type: leaves
zone: zone.home
condition:
- condition: and
conditions:
- condition: device
type: is_not_home
- condition: device
type: is_not_home
- condition: numeric_state
entity_id: weather.huis
attribute: temperature
below: '20'
- condition: time
after: 06:00:00
before: '12:00:00'
attribute: forecast
above: '25'
action:
- type: turn_on
entity_id: light.fan_speed_setpoint
domain: light
brightness_pct: 2
- service: notify.mobile_app_marcel
data:
title: Ventilation started!
message: The ventilation speed is set to: 2
mode: single
Set back ventilation speed to level 1:
Triggers:
- Someone gets home (enters a zone)
- The actual outdoor temperature has reached more than 20°C
Actions:
- Set fand speed level to: 1
The HA script:
- id: 'xxxxxxxxxx'
alias: Stop ventilation
trigger:
- platform: device
type: enters
zone: zone.home
- platform: device
type: enters
zone: zone.home
- platform: numeric_state
above: '20'
condition: []
action:
- type: turn_on
domain: light
brightness_pct: 1
mode: single
As you can see from the script, the FAN speed is treated like a light (dimming), this "issue" is described in the project details section.
Now it's waiting for the summertime to see if the automation works well..... but more importantly, if it really improves the temperature and air quality :)
