Story
I have already made so many wifi-controlled robots at home using ESP8266. Now, I have decided to make the same wifi-controlled bot but with an upgraded version. So here I am going to make a self-balancing bot. I really hope this will be more interesting than before. so, let's make it together...And yes of course l have tried to make it as simple as possible and assure that anyone can make it easy with this tutorial...
WHAT WILL YOU LEARN FROM THIS TUTORIAL
  • About Node MCU
  • how to upload code in esp8266
  • about l298n
  • what is a self-balancing robot
  • how to make PCB
  • why should we use PCBs in our project
  • how to control the bot via mobile phone
NODE MCU
NodeMCU is an open-source IoT platform. It includes firmware that runs on the ESP8266 Wi-Fi SoC from Espressif Systems, and hardware that is based on the ESP-12 module. The term "NodeMCU" by default refers to the firmware rather than the development kits. The firmware uses the Lua scripting language.
WHY NODE MCU/ESP8266 IS USED IN IOT PROJECTS?
ESP8266 has very low cost and high features which makes it an ideal module for the Internet Of Things (IoT). It can be used in any application that requires it to connect a device to the local network or the internet. NodeMCU Development Board/kit v1. 0 (Version2) NodeMCU is an Arduino-like device.
HOW TO UPLOAD THE CODE IN NODE MCU?
Please follow the steps below, If you are new and not well familiar with this ESP8266 module, or facing a problem while uploading the code
1.First Download the code from the link below. Now open Arduino and Go to File~New.
2.Now a new window will appear. Next, Delete all the existing code and Paste the given code.
3.In the code, you will find Additional Board Manager URL now copy the URL and do the next step. For Different OS you have a different option. MAC: Go to Arduino ~ Preferences Windows: Fille ~ Preferences
4.Now Paste it in the Additional Board Manager URL section and press Ok. Now go to Tools ~ Board ~ Boards Manager Search for ‘ESP8266‘ and install the latest version.
5.After the installation Then go to Tools ~ Board and then select the ESP-12E Module. So, The Board is selected Now.
6.Next, Select the Right COM Port.
7.Then compile the Programme First and then Upload it to NodeMCU. After a few seconds, the code will be compiled and then Uploaded to NodeMCU Car.
WHAT IS L298N AND WHY USE IT?
The L298N is an integrated monolithic circuit in a 15- lead Multiwatt and PowerSO20 packages. It is a high voltage, a high current dual full-bridge driver designed to accept standard TTL logic level sand drive inductive loads such as relays, solenoids, DC, and stepping motors.
The L298N is a dual H-Bridge motor driver which allows speed and direction control of two DC motors at the same time. The module can drive DC motors that have voltages between 5 and 35V, with a peak current up to 2A.
WHAT IS THE SELF-BALANCING ROBOT?
The two-wheeled self-balancing robot represents a robotic platform with two independently actuated wheels and a center of gravity above the axis of the rotation of the wheels. The behavior of the robot is similar to the classical mechanical system of an inverted pendulum.
What does PCB mean?
printed circuit board
printed circuit board, PC board, or PCB, is a non-conductive material with conductive lines printed or etched. Electronic components are mounted on the board and the traces connect the components together to form a working circuit or assembly.
Why should we use PCBs in our project?
An effective PCB design can help in reducing the chances of errors and also the possibilities of short circuits. PCBs have a vital role in this modern-day as technology is improving daily. These circuit boards are the foundation of electronic products as they are used in almost every electronic device.
HOW TO MAKE PCB BOARDS EASILY?
Making PCB boards at home is possible but it's really very hard to make and takes a lot of time. But it...
