Generation Comparison
A project log for Home Assistant Solar Tracker
Solar Tracker based on ESP32 with low cost actuators integrated on Home Assistant
vinis-labVini's Lab 03/11/2022 at 16:220 Comments
On the chart bellow you can see our best generation day, without any clouds, before installing the tracker:
The generation was 14,22kWh.
On the second chart the results are with active tracking, some clouds happened so we expect even better results:
The generation was 16,41kWh.
