Final PCB Schematic decisions
A project log for Home Assistant Solar Tracker
Solar Tracker based on ESP32 with low cost actuators integrated on Home Assistant
vinis-labVini's Lab 04/29/2022 at 17:140 Comments
For the final PCB Design, I am adding a Spark gap and Zener diodes for input protection.
On the prototype, I am currently using two relays to turn the motor on. In the final design, only one relay will be used to reverse the motor direction, since this relay is used only twice a day it should last forever.
The movement relay is being replaced by a PCB solid state relay.
The logic power supply is also being replaced from a charger adaptor to a Meanwell power supply module soldered on the PCB.
