Why Global Shutter?
For some applications with fast-moving scenarios, rolling shutter cameras will have distortion effects which leads to the input image data being invalid. Global Shutter cameras perform better.
Details about the Global Shutter Camera Module for Raspberry Pi and Jetson Nano
This camera module is combined with two parts: an AR0234CS sensor-based camera module we previously built for OpenNCC, and a daughterboard with connectors compatible with Raspberry Pi 4B.
What to mention is this camera module offers two different types: Color(RGB) and Monochrome.
Since Jetson Nano also uses the same camera connector as Raspberry Pi 4B, this camera module can also work with Jetson Nano.
We also build an industrial USB camera using the AR0234CS sensor, to secure the connection with long distances.
Purchase Links for Onsemi AR0234CS based Global Shutter Cameras:
Johanna Shi
Passamonti Francesco
Ivmech Mechatronics Ltd.
Arducam
