Scan surrounding Wifi
In this project, we use BW16 to scan available WiFi hotspots in the surroundings.
In this project, we use BW16 to scan available WiFi hotspots in the surroundings and print the SSID, encryption type, signal strength information of each detected hotspot.
Ameba RTL8722DM is a low-power dual-band WLAN and Bluetooth Low Energy SoC by Realtek. The RTL8722DM also include memory for Wi-Fi protocol functions and application making it simple for anyone to develop various kind of IoT applications. At the same time it has a wide range of peripheral interfaces. With all these interfaces, it can connect to most of the electronics components like LEDs, temperature and humidity sensors, and so on.
More Resources:
If you need additional technical documents or the source code for this project. Please visit the official websites and join the Facebook group and forum.
Ameba Official Website: https://www.amebaiot.com/en/
Ameba Facebook Group: https://www.facebook.com/groups/amebaioten
Ameba Forum: https://forum.amebaiot.com/
  • 1 × BW16
  • 1
    Setup
    First, make sure the correct Ameba development board is selected in Arduino IDE: “Tools” -> “Board” ->
    Open the “ScanNetworks” example in “File” -> “Examples” -> “AmebaWiFi” -> “ScanNetworks”:
    wifi-1-2
  • 2
    Final Result
    Then upload the sample code and press the reset button on Ameba. Afterward, you can see the “**Scan Networks**” message appears, with the detected WiFi hotspots and the information of each hotspot.
    wifi-1-2
View all instructions
