1Before You Build
Prerequisite reading
Before you buy the parts and tools to build this rig, please carefully read through the following.
- By reading these instructions and/or building this VR support rig, you agree to my liability disclaimer.
- Please read this log on if you should even build this rig and VR shoes.
- This rig is meant to be used with my passive VR shoes. You'll need to build those too. You can read about those here.
- This rig has a feature list on its project page, in the description.
- I also have a ceiling mounted rig. You can read my comparison of the two here. The other rig might be better suited to your needs.
- I used a specific half-body safety harness for my build. It couples to the rest of the rig in a specific way. If you use a different climbing harness with a different design, you may need to figure out a different way of coupling it to the rest of the rig.
Again, please read everything above before you spend the money on the parts for this rig and the time building this rig. My setup is niche and not for everyone.
2TODO
Any estimate on when the instructions will be ready?
