FAQ
A contest log for Supplyframe DesignLab: 2022 Hackaday Prize
A global hardware design challenge focused on widespread and impactful innovation.
lutetiumLutetium 03/29/2022 at 04:500 Comments
The 2022 Hackaday Prize FAQ
How do I enter?
There is a drop down menu below your project image. Simply start a project and click the dropdown, from there you will see 2022 Hackaday Prize. You will only be able to enter the challenge that is open at the time you are submitting.
What is considered an entry?
Put simply, you need an idea, an image, and documentation. To start, choose a challenge to address, or talk about a technology problem facing people today and your idea of what a solution might be and enter it to the Wildcard Challenge.
From your documentation, others should be able to build what you're working on, and incorporate the best ideas into their own projects. To be eligible for judging you must have the entry round requirements completed by the close date of the challenge you are entering.
Those who need a little more inspiration will excel in any of the first four challenges. But everyone should enter the Wildcard Challenge too as it encourages you to plan well, working though problems before they become huge prototyping issues.
What are the 2022 Hackaday Prize Challenges? When do they start/end?
Choose to enter any of these five challenges.
How do I see which projects have already been entered?
Check out this full list of official entries.
How much of my Project Profile will I be judged upon?
All parts of your project will be judged. We recommend you start with a brief summary to provide an overall understanding of your project. From there, explain each part in detail, adding images and diagrams as needed. A video is only required for the final round, but if you want to make one to help walk through your project that is a great idea.
Where do I submit my prize project entry video?
On the Edit Project page add the link to your entry video in the Contest Entry Videos field and click save.
What does "open" actually mean?
Open refers to how much you have documented about your project and how much you will make available to the public when you push your project out into the world. Optimally, we would like to see open source drivers, hardware, and development tools; the final project would also be licensed as open source (using the wide range of licenses that are possible). This is a judging preference, so providing design files in a format that uses open source tools (and therefore allows others to easily use or modify them), will help you with the best chance of edging out your competition.
What are the judges using as criteria for who moves on to the final round?
You must complete the minimum entry requirements for the Challenge. Challenge entries will be judged on the following criteria:
What are the judges using as criteria to select the top ten winners?
Finalist entries will be judged on the following criteria:
I was a finalist in 2014, 2015, 2016, 2017, 2018, 2019, 2020, or 2021 can I enter the same project again?
If you won anything in a previous presentation of The Hackaday Prize that project is not eligible for entry in this Contest. You may enter with a substantially different project.
Can I re-enter my project from 2014, 2015, 2016, 2017, 2018, 2019, 2020 or 2021?
You can enter a previous Prize entry, but you must create a new project page and the project must be significantly different from when previously entered and show meaningful development during the course of the Contest.
I'm under 18, are there special rules around entering?
Yes, you must fill out a consent form and have a parent or guardian sign it. When you click on the dropdown under your project profile to enter the Prize, you'll get a screen with a link to download the consent form. Here is a link to the consent form.
Where can I see the Hackaday Prize 2022 entries?
Hackaday.io lists all of the Hackaday Prize 2022 projects entered.
