Hackaday.io Hackaday.io
Recently Updated Most Likes Newest Project Lists
Courses Tutorials Events Hackerspaces Profiles Hackaday.com Tindie Marketplace
Sign up Log in
DIY Tesla-Coil Winding Machine
Winding Teslacoils with 0.05mm Wire!!!
LeonLeon
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
1 followers
  • Description
  • Details
  • Files 1
    • View all
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
127
0
1
0
Team (1)
  • LeonLeon
Join this project's team
completed project
hardware
teslacoil winding machine COIL WINDER diy TESLA Teslaundmehr
This project was created on 03/27/2022 and last updated 10 months ago.
Description
In our modern world, almost everything is now automated. This has many advantages, and of cause also disadvantages. But honestly, I personally wound enough Tesla coils by hand in my life. In principle, the function of a coil winding machine is quite simple. We have a tube onto which the coil is to be wound. The tube rotates. Parallel to the tube is a rail with a slider that guides the wire. The coil is wound by the rotation of the tube. However, we want to have all the windings perfectly next to each other. Therefore, the slider moves a little bit to the side after each rotation. Logically, the movement should be as large as the diameter of the wire.
Project Video on Youtube: https://www.youtube.com/watch?v=qxfDYMZw_xw
This project is sponsored by JLC PCB: PCB from $0 (Free Setup,Free Stencil), Get Coupons Here: https://jlcpcb.com/IYB
In my opinion the best PCB manufactuer!
Details
Files
Wickelmaschine_v4.txt
plain - 24.68 kB - 03/27/2022 at 15:52
Download
Log In/Sign up to comment
Sign up with Github
OR
Our AngryStormCloud PCB can be turned into a flashy pair of earrings!
Project Owner Contributor
Angry Storm Cloud Earrings
Alpenglow IndustriesAlpenglow Industries
Homemade aluminum PCB holder for soldering SMD components
DIY PCB holder
SaimonSaimon
The 2018 Hackaday Prize
Portable induction heater based on cheap chinese ZVS PCB with 3D printed body and watercooling
How to make usable induction heater from ZVS PCB
CostaCosta
How to assemble your PCBs AFAP (as fast as possible)
SMD PCB assy Fast and Furious
Andrey VAndrey V
Going up?
© 2023 Hackaday
Yes, delete it Cancel
You are about to report the project "DIY Tesla-Coil Winding Machine", please tell us the reason.
Send message
Remove Member
