Introduction
Audio amplifiers are the circuits that transform low-power input audio signals into high-power audio signals at the output. The purpose of the circuits is to provide a noise-free, efficient, and low distorted audio signal with greater magnitude at the output. Different devices use different kinds of audio amplifiers. The amplifier devices usually have two stages, a pre-amplifier that only amplifies voltage gain and not the current gain, and a power amplifier that necessitates power modification of the audio signal. So, this article is about making a power amplifier using a 2SC5200 Power transistor.
PCBWay commits to meeting the needs of its customers from different industries in terms of quality, delivery, cost-effectiveness, and any other demanding requests. As one of the most experienced PCB manufacturers in China. They pride themselves to be your best business partners as well as good friends in every aspect of your PCB needs.
PCB Prototype for $5 Only (Any Color):
Hardware Required
Circuit Diagram
Application and Uses
  • Public addressing systems.
  • Audio instruments.
  • Sound reinforcement system, etc.
