Stepping clock coil directly?
A project log for Life Time
Hacking an analog clock to display a life
henry-yorkHenry York 03/28/2022 at 16:270 Comments
So far I have been controlling the clock by pulsing the pads on the PCB where the crystal oscillator used to be. The ESP8266 board I am using to control the clock sends a square wave into the PCB with a frequency based on the amount of time it is set up to display (a life, a year, a weekend...) It seems to work pretty well, but I think accuracy could be increased by stepping the clock in a different way.
Inside the clock is a coil that when pulsed, steps the internal gearing of the clock. By connecting GPIO pins on the ESP8266 directly to that coil I should be able to control the clock's movement with better accuracy, especially over longer periods of time.
