Added Design Document to Repository
A project log for Variable Pitch Small-Scale Wind Turbine
Developing a 3D Printed Variable Pitch Wind Turbine
william.rigbywilliam.rigby 04/26/2022 at 13:380 Comments
So far I've determined the average wind speed of the deployment location from online sources, and added some research documents on turbine airfoil selection from the National Renewable Energy Laboratory.
At this time I will likely use either the NACA 2412 or 4412 airfoils, or one of the NREL S-series airfoils.
